How to simulate the flow and heat transfer of phase change materials?
Old   December 21, 2007, 05:04
Default How to simulate the flow and heat transfer of phase change materials?
rosol
Dear all ,
I have to simulate the flow and heat transfer of phase change materials in fluent but I don't know how to do that in fluent what is the difference from the pure fluid and how to introduce the effect of phase change and the meltting of pcm since the energy equation is differ from the single fluid.
Please who know how to do that to help me because I need that urgently
Thanks alot
Old   December 30, 2007, 07:18
Default re: How to simulate the flow and heat transfer of phase change materials?
chaos_zzy
Dear Rosol,
You can read FLUNT help about "solidification/melt" model and there is a case about "casting", told how to use it.
Old   December 30, 2007, 13:36
rosol
Dear chaos thank you for your response,
My work is not on complete solidification i,e the fluid is suspension of water and microencapsulated pgase change material .the fluent help speaking about solidification of metals .please if you have an idea about that to help me.
Regards
Old   January 1, 2008, 02:57
chaos_zzy
Dear rosol,
I just begin to learn PCM simulation recently. I think maybe you can first calculate the PCM boundary condition in water, set PCM as solid,Then build PCM separately with boundary condition(obtain from first calculation).
Regards and Hayyp new year.
Old   January 3, 2008, 07:47
sudhir
hello rosol and chaos,
im doing on project simulation of solidification of pcm.generally pcm have two density at different phases. how to incorporate this condition in fluent?
Old   January 3, 2008, 20:59
chaos
Hello sudhir,
In fluent, you can set a polynomial(density vs temperature)to incoporate two density at different phases.
There are detailed explanation in fluent help at Modeling Solidification.
Old   January 4, 2008, 11:00
rosol
In melting of pcm as I know the density of pcm is an avarage of liquid and solid phase .But in solidification I do not have enough information.
Regards
Rosol
Old   January 7, 2008, 02:48
sudhir
thank u for ur informatin frnds.
Old   November 3, 2015, 14:56
Default Modeling melting/solidification density equation problem!
farah is on a distinguished road
Originally Posted by chaos
;147619
Hello sudhir,
I am trying to model melting process and i have two different densities one for the liquid phase and the other for the solid phase also i read all the detailed in the fluent help at Modeling Solidification but they didn't mention how to do these two densities in one equation ? and i think the values of C1 & C2 are different in each cases therefore i cannot depend on the vales in the fluent help. My question is how to make one equation of liquid phase density & solid phase density in one equation? Help me please .
farah is offline   Reply With Quote
Old   April 10, 2016, 15:22
Abhay Rana
abhay.uiet is on a distinguished road
try DEFINE_SPECIFIC_HEAT, MACRO IN UDF..it has to be compiled
abhay.uiet is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
error message cuteapathy CFX 14 March 20, 2012 07:45
