December 17, 2007, 06:22 |
Creating a new zone in Fluent
Hello, I want to create a new zone of separated cells in Fluent, in which I will input a source term condition, how can I do that ? Thans a lot for your replies.
December 17, 2007, 07:13 |
Re: Creating a new zone in Fluent
Firstly mark the region you wnt to separate out using the command
Adapt/region/mark once marked the cells you want to separate...then you can separate them n creat a new zone by grid/separate/cells Hope it serves your purpose..! |
December 17, 2007, 10:05 |
Ok for that. Now if I want to put a positive mass flow rate (fluid entering the domain) with a constant temperature, how can I define temperature of the fluid ? Do I define the energy of the fluid in W/m3, but how to calculate it ? It is function of a difference of temperature in a time step and in my case there is no variation of the fluid temperature.
December 18, 2007, 00:21 |
Hi
I am not sure of the solution but if you know hoe to define source term then while defining energy you should know that w/m3.0C is specific heat for the fluid so if multiplied by the desired temp. value the resultant unit will be w/m3......! Hope it serves your purpose...but do check with fluent manual..! |
error in fluent | anna | CFX | 2 | October 22, 2013 08:00 |
is it possible to define zone in fluent? | arashsadeqy | Main CFD Forum | 1 | June 19, 2009 02:20 |
SOLVING MODIFIED FLUENT EQUATIONS IN SECOND ZONE | HAMIDREZA | FLUENT | 0 | March 4, 2009 07:32 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 06:56 |
