symmetric boundary condition relation with force |
December 12, 2007, 10:33 |
Hi, I am simulating a 1 meter span naca0012 wing (no taper, just extruded airfoil). I have meshed half domain 0.5m span wing and applied symmetric boundary conditoin. How can I get the torque by actual 1m span wing around any specific point? Reference length is 1 meter. Thanks for your help. Endee
December 12, 2007, 12:09 |
Re: symmetric boundary condition relation with for
Just to explain my question further: If I calculate the Cm of NACA0012 in 2D and then in 3D (1 m span), with the same reference values in both cases, should the Cm be matching ideally?
December 16, 2007, 04:54 |
hi dear m doing the same problem. If u got the result, that will be my pleasure if u give me some instruction. I have all ready plotted the airfoil in 2d and 3d. But what will be the exact boundary condition??
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Setting outlet Pressure boundary condition using CAFFA code | Mukund Pondkule | Main CFD Forum | 0 | March 16, 2011 03:23 |
[snappyHexMesh] Add layers- symmetric boundary condition | prapanj | OpenFOAM Meshing & Mesh Conversion | 4 | May 28, 2009 23:49 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
Airfoil boundary condition | Frank | Main CFD Forum | 1 | April 21, 2008 18:36 |
