error while running iteration
Old   December 10, 2007, 01:51
Default error while running iteration
Rajavel
i am getting error while running iteration
like following lines
reversed flow in 1 faces on outflow 6.
what shoud i do
Old   December 10, 2007, 04:27
Default Re: error while running iteration
ravi
pls check the outlet boundary conditions like turbulent intensity and Hyd. diameter.. or if possible change them.. try with second order upwind also..
Old   December 17, 2007, 07:05
sushii
to supress "reversed flow" warning message, use the text interface command: /solve/set/flow warnings? no
or enter the following scheme command within the fluent console window: (rpsetvar 'flow-warnigns? #f)
to reenable these warning messages, replace "no" with "yes" in the text interface commands above and "#f" with "#t" in the scheme command above...!
Hope it serves your purpose...!
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 23:30
Doubt - while running iteration, plz help sak FLUENT 0 September 7, 2005 00:16
Heat exchanger problem chiseung FLUENT 16 October 20, 2001 05:36
