Hi, Is there any option in FLUENT to difine more than one reference frame.? I have a problem that i have a rocket with fins and Cannards and i want to give a Deflection in cannrads only plus the Side-slip angle of the wole body. As only the Cannrad will move bt not the Fins. means Cannards have Def angle bt Fins are fixed and hav angle equal to Side Slip So i think I need a seperate Ref Frame at Cannard to define its deflection. plus otherwise for each deflection i will have to create a separate mesh
MRF,see the fluent users'guide as far as i know, separate zones for separate component, after that you can set different reference frame for different zones.
yeah I know that but its for MOVING Refrance frame NOT for MULTIPLE refrenece frame.
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
Multiple Rotating Reference Frames for autoclave | multiphase-flow | FLUENT | 1 | June 22, 2008 21:25 |
Multiple Refrance Frames | Shamoon | FLUENT | 0 | December 4, 2007 10:44 |
Multiple reference frames? | Moon | Siemens | 0 | March 4, 2003 06:32 |
