effekt of surface roughness very small
Old   December 7, 2007, 06:46
Default effekt of surface roughness very small
Ralf Schmidt
Hi!
We did a simulation of heat transfer from a submerged body into a gas flow (2D, air, inkompr., Re = 10,000 based on body dimension, Tu of the upstream flow = 10%) with differnet surface roughness values and turbulence moddels.
BUT: There is allmost no effect of the wall roughness hight on the Heat transfer. Even a value of 50 µm is resulting in a max. 1% decreased Nu number compared to a smooth surface (k-w sst with yplus between 1 and 5 an also k-e, std wall function yplus 30-80),
What is the reason?? And even if the magnitude of the changes is ok - i would wonder about the direktion. I would expect the heat transfer to be higher for a rough wall!
Any idea??
Ralf
nutRoughWallFunction and Surface Roughness Documented AlanR OpenFOAM Programming & Development 64 January 6, 2024 08:13
Surface Roughness Jochem OpenFOAM 2 July 6, 2011 07:17
Decreasing surface roughness in a pipe pat FLUENT 0 June 12, 2006 12:22
Setting a surface roughness on a wall Sandile Peta FLUENT 1 February 3, 2006 08:09
roughness of thin surface colins CFX 5 October 30, 2003 01:13
