December 6, 2007, 06:18 |
boiling, drag_force
Hi Folks,
i am using the boiling tutorial. In DEFINE_EXCHANGE_PROPERTY the drag coefficient is calculated. Instead of this coefficient the drag force/urel is returned. I think that is wrong. in literature: (Drag Force = 0.125 * drag_coeff * C_R(c,pt[second_column_phase_index]) * Ai * urel * urel) Could anybody help, maybe i have got an error in reasoning. Thank you. /* Calculation of the drag coefficient */ drag_vis = 24.*(1.+0.1*pow(reb,0.75))/MAX(reb,1e-10) / pow(MAX(1-vof_vapor,0.5),2.); Rol = C_R(c,pt[second_column_phase_index]); Rov = C_R(c,pt[first_column_phase_index]); coeff = (Rol-Rov)*gravity/sigma ; drag_coeff = 0.666*dbub*pow(coeff,0.5) / pow(MAX(1-vof_vapor,0.5),1.0); if (drag_vis > drag_coeff) drag_coeff = drag_vis; drag_force = 0.125 * drag_coeff * C_R(c,pt[second_column_phase_index]) * Ai * urel ; C_UDMI(c,mixture_thread,3) = drag_force * urel * urel; C_UDMI(c,mixture_thread,4) = 0.45 * C_UDMI(c,mixture_thread,3) * drag_coeff * urel / dbub; return drag_force; |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Stability problem due to turbulent dispersion force in a subcooled boiling model | Edy | OpenFOAM | 7 | August 10, 2011 13:00 |
Boiling on Mountaintop | Frank | Main CFD Forum | 3 | January 16, 2009 17:33 |
VOF vs BOILING | greg | FLUENT | 0 | April 1, 2007 11:59 |
pool boiling curve | David Gibson | Main CFD Forum | 0 | November 11, 1998 00:06 |
