Unable to write case and data...!
Old   December 6, 2007, 02:44
Default Unable to write case and data...!
sushii
Hi there,
I am running a VOF simulation, I have set run with auto save....but it is not at all working...not a single case and data file is written...even after four thousand iterations....! also when I tried to write case and data it show some memory error as...some "malloc_st..xxxxx...myid ###..." can any one help me...? what could be the problem...?
Thanks in advance...!
--Sushil.
Old   December 6, 2007, 03:00
Default ST_Malloc: out of memory.malloc_storage...!
sushii
The exact error is as follows..
Warning:ST_Malloc: out of memory.malloc_storage: uanble to malloc id, size 5586384, t 19, myid 1000000.
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
Even I tried to save it under new name...but failed each time...n I am having enough free space on my disk..so no problem with that ...I am not getting why this error is there...!
Old   December 6, 2007, 03:28
Default Re: ST_Malloc: out of memory.malloc_storage...!
hari
this error is mainly due to the insufficient system memory or very high magnitude in boundary condition which could not be calculated by the processor
Hari V.B.
Old   December 6, 2007, 06:59
Sujay
what is the value u gave in the solve monitor residual storage iterations? It's default value is 1000 iterations
Old   December 7, 2007, 02:12
Jim Clancy
means low memory
How to read or write case by commands during simulation with Fluent lzgwhy FLUENT 4 April 20, 2011 23:02
Writing Case and Data Files Using Journal/Scheme Files svp Fluent UDF and Scheme Programming 0 April 5, 2011 12:04
fluent case n data files not exporting to tecplot krishna FLUENT 2 February 18, 2007 00:24
how to save case data and data during iteration? JOHN FLUENT 3 October 10, 2006 20:40
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
