write a xy data file every timestep
Old   December 4, 2007, 09:46
Default write a xy data file every timestep
pieter brodeoux
We are using fluent to simulate the heat transfer in a heat exchanger. How can I write an xy data file every timestep to evaluate the average surface heat transfer? many thanks in advance!
Old   December 5, 2007, 18:30
Default Re: write a xy data file every timestep
cfd-newbie
Try:
solve -> monitor -> surface
then you could select what type of report you want ... integral, vertex-averaged etc ...
If this isn't helpful, you could try to define a macro with exactly what you want to do and execute this macro at the end of every time-step.
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
UDF (write a data file) problem lichun Dong FLUENT 2 July 29, 2005 12:39
