register the mass fraction of species!
Old   December 3, 2007, 16:45
Default register the mass fraction of species!
HaiDuc
Hi all!
I need help for the following calculation.
Situation:
I have 2 different volumen. The first small one (0,3 m3) contains schwefelhaxefliud (SF6) as fluid and has an overpressure of 50 kPa and the temperature is 1500 K. The other bigger one (10 m3) consits air as fluid and the temperature is 300K. This two volumen are joined by an small area (0,02 m2) havind an interior character. The SF6 will flow through the area into other volumen if the calculation starts. From this time it would be a mixed fluid.
Problem:
I want to register the fraction of air and SF6 separately. That means e.g. I want to know how many fraction of SF6 or air are effused. The result should be a function in term of time.
Has someone an idea to solve this problem.
Thanks a lot
Hai Duc
mass fraction of species Lilly FLUENT 5 March 13, 2022 18:52
gradient of species mass fraction zhou FLUENT 1 March 14, 2020 08:55
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
