pls. help : life-drag coefficient in dynamic mesh
Old   November 30, 2007, 13:20
Default pls. help : life-drag coefficient in dynamic mesh
loogtaan
I solve flapping motion by using dynamic mesh but I don't know hoe to define force vector for cl,cd plot in force monitor.Have anyone can suggest me.
thanks.
Old   December 1, 2007, 03:16
Default Re: pls. help : life-drag coefficient in dynamic m
zhang
firt,you can't define the foce vector, there are only three options you can choose:x_axis,y-axis and z-axis. but you can rotate the mesh to get different vector
second, force monitor just plots the force coefficient.you must know how to change the reference value to get the real forces
Old   December 1, 2007, 09:32
loogtaan
Thank you Zhang,
But I don't know how to change the reference value because I use only DEFINE_CG_MOTION to predict airfoil motion. Please explain me.
loogtaan
Old   December 1, 2007, 09:42
loogtaan
This is my udf code
#include <udf.h> #define PI 3.141592654
DEFINE_CG_MOTION(airfoil, dt, cg_vel, cg_omega, time, dtime) {
real freq = 1.707;
real amp = 1.4;
cg_vel[0] = 2*PI*freq*amp*sin(2.0*PI*freq*time); /* x-velocity*/
cg_omega[2] = 2*PI*freq*0.78534*(sin((2.0*PI*freq*time)+1.5708)) ;/*angular-velocity*/
Old   December 8, 2007, 23:15
zhang
Sorry loogtaan, I'm being busy on my job thess days. Beyond the report menu, you can see the reference values.Once you change denstity 1.225 to 2. The forces in the "Force Monitors" become the real forces
Old   December 20, 2007, 21:54
loogtaan
Thank you Zhang,
could you told me how about the velocity that I must use in the reference menu because I give same result for different Renolds Number.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Dynamic mesh update problem. David FLUENT 3 March 15, 2012 06:02
Dynamic Mesh moving interface help akash.iitb FLUENT 0 August 24, 2010 00:53
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 16:40
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 13:19
