UDF: parse error
Old   November 26, 2007, 14:27
Default UDF: parse error
manu
I'm doing a simple DEFINE_ON_DEMAND function in a UDF and I always get the same error at some places and I don't understand why at all: "parse error at line ..." I looked on internet what people say about this error: some people say that's a problem of UDM (User Define Memory), other people say that we must use compiled and not interpreted UDF but for me that's chinese. Can someone tell me what to do? Thanks
Old   December 2, 2007, 03:04
Default Re: UDF: parse error
mohanraj
1. All the variables needs to be declared at the top(before starting you manipulation or calculations); 2. Parse error occurs when you miss ";" at the end of the line. 3. If you are transferring the ".c" file from windows system to unix system there may be ^M characters sitting at the end of the line. This may lead to some errors.
Old   December 4, 2007, 04:19
manu
Thanks for the information but I think I have something more special because I made tests of my code, so that I can compile each part of it, but when I put all the parts together it doesn't work and I allways get this "PARSE ERROR" and "INVALID TYPE FOR POINTER DEREFERENCE:FLOAT" at some place of my code...
Old   December 4, 2007, 13:09
mohanraj
Pls. check that you have put in all the required library on the top of your program. Also, post the two lines of the code (ie. before and after the line error) after checking the braces({}) balance and ";"
parse error in transient udf spring FLUENT 1 July 6, 2010 07:26
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 10:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
