mismatch between heat flux value
Old   November 19, 2007, 16:59
Default mismatch between heat flux value
Vaibhav Khane
Hi friends
I have defined simple cylinderical geometry.
I have given heat flux value conditions for both the faces.
& circumferential face is being insulated.
I am getting less value on side where heat enters the geometry than where it leaves the geometry.
3619.92 against 4000
(The area of both the faces is same)
I have done steady state as well as unsteady state analysis.
Please tell me why it is happening.
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 17:25
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
Total Heat Transfer Rate & Total Surface Heat Flux Mismatch icaro FLUENT 0 November 24, 2009 08:01
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 06:09
