Lifted flame simulation!!!
Old   November 11, 2007, 12:07
Default Lifted flame simulation!!!
krishh
Hi i am trying to simulate non premixed confined turbulent propane lifted flames. I am using species transport model and in that laminar finite rate model for turbulent chemistry interactions. But the flame is not getting lifted upon increasing the velocity beyond 25m/s and the simulation lift off height is not matching with experimental lift off height. For 25m/s fuel velocity and pressure inlet condition for air,single step chemistry,k-e turbulent model: Experimental height =96mm Simulation lift off height=50mm. why this much discrepancy between experimental and simulation results. I tried with eddy dissipation model;laminar finite rate/k-e model;eddy dissipation model;EDC model. out of which i can achieve lift off of flame only when i am using laminar finite rate model or EDC model but EDC is over predicting the results. can u suggest me what i need to do to achieve correct lift off height(i.e my suggesting any particular model or the changes i need to make)
Old   August 26, 2009, 06:17
Smile hi
siva kumar
shshiva17 is on a distinguished road
send ur experimental results and gepmetry,, i will say the correct solution,,,
moreover hav u considered any wall thickness???
my email id is :shshiva17@gmail.com
shshiva17 is offline   Reply With Quote
ReactingFoam Laminar flame simulation transport properties gbansal OpenFOAM Running, Solving & CFD 3 November 23, 2012 17:03
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 09:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 19:57
combustion bomb simulation ... bart_weisser FLUENT 0 April 25, 2010 03:41
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 14:02
