problem about DPM of cyclone separator simulation |
November 10, 2007, 02:29 |
I met a problem about DPM of cyclone separator simulation. I have got the converger result of gas flow field in cyclone. But when I added DPM into it, some error happened. some like float point error. Are there some special issue to be noticed when using DPM? I just take the routine, such as the same particle diameter(i.e.5um),group injection... Another problem is how to control the number of particle injection ?
Thanks a lot |
November 10, 2007, 03:09 |
Re: problem about DPM of cyclone separator simulat
Hi Dear Jason, What injector you use? If you use from File injector in the injection panel maybe your particle coordinate do not match with your geomatry. Of cource i think. good luck
Morteza |
November 10, 2007, 03:14 |
Thanks I just used the surface injection as inlet. I am new about DPM, so I just wanna calculate the grade efficiency. Bad Luck. Wrong Results. WHY?
November 10, 2007, 16:43 |
First of all, use single injection; it is possible that your simulation lead to result, after this step use other injections. Can you introduce yourself? What's your field of study, your university and your course, please?
November 12, 2007, 03:15 |
If you use surface inlet injection then the number of particles you inject is equal to the number of cells on this surface. If you want to controlyour injection, you can create a plan and enable bounded and sample points, choose the number of point on each direction. Then you will use this surface to be your injection surface. Be sure that this surface is included in your geometry: Hope it helps
Cyclone Simulation Convergence Problem | Sal | FLUENT | 8 | December 17, 2014 07:46 |
DPM Output Problem (Again...) | DLINSA | Fluent UDF and Scheme Programming | 1 | March 16, 2012 00:45 |
Cyclone seperator, problem with slip vel | -seb- | FLUENT | 0 | November 5, 2009 09:59 |
I have a big problem at the DPM | motallebi | Fluent UDF and Scheme Programming | 0 | July 3, 2009 04:13 |
how to do with the DPM problem? | x.p.lee | FLUENT | 1 | June 26, 2003 13:07 |
