how to delete the vertices on the edges
Old   November 9, 2007, 18:34
Default how to delete the vertices on the edges
Justin
Hi, all,
some vertexes are not necessary on the edges,but cannot be deleted due to upper topology entity. Any advice? Thanks in advance.
Justin
Old   November 12, 2007, 07:13
Default Re: how to delete the vertices on the edges
sushii
Hi...! You can merge these edges...vertices will be automatically deleted...! Hope it could work...!
Old   November 12, 2007, 16:36
Justin
Thank you very much! It does work. Before I thought the merge function was just for virtual edges.
Cheers Justin
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
