spercritical fluid flow in porous media
Old   November 8, 2007, 20:56
Default spercritical fluid flow in porous media
cachen
dear all:
Do you have experience to simulated supercritical fluid or porous media?
How to set up for supercritical fluid in FLUENT? And in fluent user's guide, it didn't wrote detail momentum equation for porous media. If i turn porous zone on,Which form of momentum equation in porous media will use in FLUENT?
My study is to combine this two in FLUENT. Can FLUENT do it?
Help me out, please.
best regard
cachen
Old   November 9, 2007, 05:24
Default Re: spercritical fluid flow in porous media
Chandra Manik
Dear Cachen, please see the document about porous media, basicly there are two formulation about it, first about inertial resistance and viscous resistance, you can find and fit the typical resistance constants by testing your porous media first in such flow condition and fit it into graphical to get coeeficient of constant (inertial and viscous).
I hope it help
Best Regards
Chandra Manik
Old   November 9, 2007, 10:24
cachen
Dear Manik:
Thank your help.
But i still have question for momentum eqaution in porous media. I know that it added two source terms for momentum equation, but i did not know it will change the form of momentum equation in porous media or not. In literature of porous media, every terms in momentum equation will have porosity effect like this equation in below link
http://www.me.ncu.edu.tw/fluent/flowmen/porous.pdf
so, i am confused this equation with FLUENT user's guide which only add two terms.
Can someone explain it? Thanks very much.
Best regard
cachen
Old   November 10, 2007, 03:20
Chandra Manik
Dear Cachen, actually you can find it the user help about porous media, it is right that momentum is change as fluent guide also said, the porous term in fluent is same with you said, it change the momentum equation, because fluent applied porous media as a source to change the momentum
see the equation manual at fluent it is informly well
Regards
Chandra Manik
[Other] Consistent mesh for fluid flow in fractured porous media bemgeomechanic OpenFOAM Meshing & Mesh Conversion 0 March 14, 2011 09:46
Testing the integrity of POROUS media and por jump Azman FLUENT 0 July 31, 2006 12:11
porous media flow Siraj Siemens 4 February 24, 2006 23:24
unidirectional flow in porous media Brian FLUENT 6 September 2, 2004 11:53
Flow in Porous Media Q.Rosa CFX 1 March 13, 2000 11:45
