S2S radiation model
Old   November 8, 2007, 11:29
Default S2S radiation model
Mo Mirsadeghi
Dear all,
I want to use S2S radiation model for my simulation. But I recive an error while computing the view factors. The error is: "FATAL ERROR: Cannot open parameter file D:\Coupling Provide full path to I/O file D:\Coupling command to execute: "C:\Fluent.Inc\utility\viewfac2.1\ntx86\vfs216.exe " D:\Coupling Validation\2d-solid\2d-solid.s2s.gz Reading "| gunzip -c \"D:\Coupling Validation\2d-solid\2d-solid.s2s.gz\""... You must read in a view factors file or disable S2S model before proceeding.
Error: Failed while reading view factor file.
Error Object: ()
Error: Error reading "| gunzip -c \"D:\Coupling Validation\2d-solid\2d-solid.s2s.gz\"". Error Object: #f "
Some information about my model: My model comprises of solid and fluid domain. So I have a coupled simulation between solid and fluid. Is this the source of error? Thanks alot in advance for your advice.
Old   December 8, 2007, 15:36
Default Re: S2S radiation model
anderson
Hi, Remove any spaces in the path where you are writing the viewfactor file. Eg. My Documents etc.. Basically, save it in a different path without the spaces.
anderson
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 4, 2013 00:04
how to write and read view factor file in radiation model S2S chhanwal FLUENT 1 March 25, 2009 11:54
radiation model brian FLUENT 0 July 27, 2007 11:57
RE: Radiation model Ashutosh Joshi FLUENT 1 January 30, 2001 11:50
