Model of Swirl Tube (Axial Reverse cyclone)
Old   November 8, 2007, 02:39
Default Model of Swirl Tube (Axial Reverse cyclone)
jason
Hello, everybody. I have noticed that there are so many people interested in cyclone seprators. And now i am doing the Model of Swirl Tube (Axial Reverse cyclone),(see A.C.Hoffmann's Book or paper). I have two questions about it when using Fluent?
1. How to get the accurate 3D guide vane model with Gambit?
2. The swirl tube is simple,but also comlicated flow behavior. So RSM is a better choise ? DPM ?
Thanks in advance
jason
Old   November 8, 2007, 05:28
Default Re: Model of Swirl Tube (Axial Reverse cyclone)
fluid
2. RSM is greatly suggested for swirling flows, even if its convergence is always so complicated..... If you want to simulate particle separation, I think DPM is mandatory... fluid
Old   November 8, 2007, 10:35
jason
Thanks But the guide vane is so important, beacause if it cannot be made with Gambit. The velocity profile calculated by Fluent must not be accurate.
The "cross talk" between the parallel swirl tubes as the third stage separator in FCC can be simulated with FLuent?
Thanks your reply
Old   November 8, 2007, 11:16
fluid
sorry, it in not my application field and I can't be "more" useful than I have already done... :-P fluid
Old   November 9, 2007, 10:27
Neil
Theres a Gambit plug-in called G-Turbo that can be used to create geometry for blades which could be of use
Old   November 9, 2007, 10:37
fluid
Ah, ok. Thanks, fluid
Old   November 9, 2007, 11:34
jason
Thanks
Now I am using Fluent 6.2.1. Where to find The Gambit plug-in called G-Turbo ? Could Neil sent one for me ?
Old   November 11, 2007, 22:35
jason
Does G-Turbo have trial edition? Anybody can provide some useful infomaion.
Axial Fan Model mardit STAR-CCM+ 0 August 28, 2010 18:16
axial flow around a cylinder -heat transfer model? Ralf Schmidt Main CFD Forum 1 March 21, 2006 09:54
SWIRL flow in cyclone Nina Main CFD Forum 2 July 28, 2005 23:02
Swirl for Axial fan JJ FLUENT 0 September 8, 2004 07:35
for help on confined swirl jet model Gui Qiaoyi Main CFD Forum 1 August 26, 2001 12:27
