help~~~sloshing problem using VOF
Old   November 6, 2007, 08:08
Default help~~~sloshing problem using VOF
shen
Hi ,everyone.
I'm doing simulation of sloshing effect of closed cylinder tank filled 80 percent with water and remaining air, and the pressure of the air is 0.3MPa. I set the boundary condition is wall. The tank is supposed to roll to-and-fro. I'm using VOF scheme. Which viscous model to choose? I chose k-e. and how can I impose the exciting amplitude and the oscillation which excite the roll motion?
I'm green hand in fluent, so if you have some examples of sloshing problem using VOF, especially the boundary conditions and the relevanr input details, would you please give me some? , Thank you in advance!
a problem of incompressible two phases(water and gas) with VOF Method zhangweisnoopy Main CFD Forum 9 August 12, 2011 09:25
Two-phase VOF problem scott copland FLUENT 3 March 15, 2007 08:25
Problem with VOF open channel modelling Biswanath Mahato FLUENT 1 September 14, 2006 05:20
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 23:00
problem with VOF. Marc FLUENT 1 June 5, 2002 09:17
