parallel computing
Old   November 5, 2007, 07:18
Default parallel computing
Daniel
Dear all; I executed fluent in parallel mode, on a computer that has 2 cpu (dual core). fluent has identified the 2 cpu but works very slowly (10% of each cpu is used), even slower than when it is executed normally. What should I do?
Tnx
Old   November 21, 2007, 17:09
Default Re: parallel computing
rj
Contact FLUENT installation support
unchangeable continuity residuals in parallel computing wlt_1985 FLUENT 0 August 1, 2011 13:15
Diffusion equation solved using Parallel Computing Sachin Paramane Main CFD Forum 0 June 12, 2007 00:48
Parallel Computing on Multi-Core Processors Upgrading Hardware CFX 6 June 7, 2007 16:54
Parallel Computing peter Main CFD Forum 7 May 15, 2006 10:53
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
