Need help in setting up a shock tube problem
Old   November 2, 2007, 15:11
Default Need help in setting up a shock tube problem
kalee
The problem is this. i have to simulate a moving shock problem (basically a shock tube problem)
Let me inform , what i have done (still no success) I am a newbie...
I have created mesh using Gambit and given two fluid zones in it separated by a 'interior'. Then i imported it in fluent and had given the properties of the two fluid zones to be the same. Then i initialised the all zones with a pressure of 1 bar and patched the fluid zone 1 to have a value of pressure equal to 10 bar. I used transient solver, laminar, enabled the energy equation and set the timesteps to 1e-5 and iterated for some 1000 steps, incrementing every 100 steps. But the problem i am having is, i couldnt see any shock propagating.. I dont know why... I may be wrong somewhere. Do help me out... Thanks in advance. The grid is very fine.
Shock tube simulation in Fluent Vinoo_P FLUENT 28 September 6, 2018 01:21
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 03:10
analytical solution of 1D shock tube problem ma Main CFD Forum 10 May 11, 2015 06:20
How to slove shock tube problem with Harten's TVD xialiuyu Main CFD Forum 0 June 17, 2007 01:57
shock tube: problem initiation Gareth Siemens 3 April 15, 2003 04:23
