Parallel runs slower with MTU=9000 than MTU=1500
Old   October 28, 2007, 23:30
Default Parallel runs slower with MTU=9000 than MTU=1500
Javier Larrondo
I have been trying to build a small cluster with 2 dual-core Pentium D pcs. I've installed SUSE SLES 10, the NIC cards are Gigabit. After two weeks struggling with the network configuration. I'm finally able to perform some benchmark.
The problems is that setting up the Jumbo Frames option on the NIC card (MTU=9000) my test case runs slower than the one with the NIC standard option (MTU=1500). Also I've seen that the MTU=9000 options don't use as much CPU than the standard option.
Does anyone have experience with this?
Any comments would be helpful. I need to improve this to request some extra funds for my research project and build a bigger beowulf cluster.
---- REFERENCE INFO ---------
Case: 464000 Hex Cells 3D, PBNS, RNG k-e, multiphase mixture model (2 phases), Multiple Reference frames, unsteady.
MTU=9000 (OPTION) Performance Timer for 40 iterations on 4 compute nodes
Average wall-clock time per iteration: 13.969 sec
Global reductions per iteration: 223 ops
Global reductions time per iteration: 0.000 sec (0.0%)
Message count per iteration: 854 messages
Data transfer per iteration: 30.742 MB
LE solves per iteration: 7 solves
LE wall-clock time per iteration: 5.445 sec
LE global solves per iteration: 2 solves
LE global wall-clock time per iteration: 0.085 sec (0.6%)
AMG cycles per iteration: 8 cycles
Relaxation sweeps per iteration: 316 sweeps
Relaxation exchanges per iteration: 76 exchanges
Time-step updates per iteration: 0.05 updates
Time-step wall-clock time per iteration: 0.015 sec (0.1%)
Total wall-clock time: 558.759 sec
Total CPU time: 1477.740 sec
MTU=1500 (OPTION) Performance Timer for 40 iterations on 4 compute nodes
Average wall-clock time per iteration: 7.700 sec
LE wall-clock time per iteration: 0.605 sec (7.9%)
LE global wall-clock time per iteration: 0.003 sec (0.0%)
Time-step wall-clock time per iteration: 0.016 sec (0.2%)
Total wall-clock time: 308.003 sec
Total CPU time: 949.780 sec
Cheers,
Javier
parallel fluent runs being killed at partitioing Ben Aga FLUENT 3 June 8, 2012 11:40
Inconsistent behaviour of gMax/gMin for parallel runs gschaider OpenFOAM Bugs 5 July 29, 2009 15:23
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Help: Serial code to parallel but even slower Zonexo Main CFD Forum 4 May 14, 2008 11:26
Distributed parallel runs on ANSYS CFX 10 Manoj Kumar CFX 4 January 25, 2006 09:00
