October 25, 2007, 03:53 |
gambit error
I have created surface mesh from edge mesh for the four sides of the domain.Domain is just like one hall supported by some pillars. When i m going to generate mesh for top and bottom surface its showing error:"zero length front edge error". is it coming due to the pillar's hollow portion of topside ?also at some places,pillars are attachd to wall so that a bent surface of 90 deg is formed.pillars are of rectangular shape.mesh generared is of triangular type.all d mesh is generated in gambit.
thanks in advance. |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 21:23 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 19:54 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 21:11 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
