October 20, 2007, 13:03 |
display velocity at wall
starcd and cfx have two different options to display the velocity at no-slip walls. One is the is the excact wall velocity at the wall, which is zero for no-slip walls, and I think,the other options display the cell value in the next boundary cell. Is it possible to do this with FLuent? I saw some starcd results, which show the air velocity distribution on the windshield of a car. Flo |
October 22, 2007, 09:24 |
Re: display velocity at wall
In a contour plot of velocity, you can toggle the "node values" option on and off... Node values on = velocity at nodes... should see zero on non-slip walls. Node values off = velocity at adjacent cell centers (similar to what your describing for cfx and starcd (I believe...)
In a vector plot, you see adjacent cell center velocities (either in absolute or relative reference frames... Node values are not available here, as plotting zero magnitude vectors does not make sense to do. |
BC set at fixedValue (0 0 0), but I get a non-zero velocity @ wall | squadron | OpenFOAM Running, Solving & CFD | 9 | May 31, 2018 10:47 |
the air velocity is not zero on the wall? | Li Rong | CFX | 5 | April 9, 2018 02:02 |
impose oscillating wall velocity | IvanCFD | FLUENT | 0 | May 13, 2010 08:53 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
display steamlines in the thin wall | Ridha | FLUENT | 2 | August 3, 2005 16:26 |
