October 19, 2007, 11:56 |
Mass outflow rate
Hello,I want to create in my model a negative mass flow rate (production term),how do I define the region of cells where this mass outflow is applied ? For the moment I have only one continuum region which is water. Thanks if you can hepl me.
October 19, 2007, 16:01 |
Re: Mass outflow rate
In your mesh, select the boundary element faces which will form the location of mass injection/extraction. Then, define the appropriate boundary condition. (ie: often, one can achieve a mass extraction by defining the BC as a mass flow inlet, but pointing the vector directions out of the boundary). If you have a solution already (which did not have this new BC location tagged in the mesh, you can "write-bc" the boundary conditions, and write interpolation file... then read in new mesh and "read-bc" and interpolate exisitng solution... with new BC location now newly defined.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Target Mass Flow Rate | Nitin | FLUENT | 9 | June 17, 2017 11:30 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 11:44 |
Target mass flow rate | Saturn | FLUENT | 0 | December 10, 2004 05:18 |
Mass flow rate on outflow face | TOM | FLUENT | 1 | February 25, 2002 11:27 |
