animation of transient simulation using batch file
Old   October 16, 2007, 12:54
Default animation of transient simulation using batch file
Markus
I'm conducting several transient simulations in fluent 6. I've already written a batch file which works just fine, except for the export of the jpeg-files. I used the /display/set/.. and /display/contours... commands like in tui to set the display windows. If I run the simulation there's just one exported jpeg-file. How can I set the batch file in order that it exports the animations each 2nd time step??
My batch file:
/rcd "/dummy.cas" yes
/define/user-defined/interpreted-functions "/dummy.c" "cpp" 10000 no
/define/user-defined/execute-on-demand "on_demand_fin"
/display/set/hardcopy/driver/jpeg
/display/set/hardcopy/invert-background? yes
/display/set/hardcopy/x-resolution 640
/display/set/hardcopy/y-resolution 480
/display/set/hardcopy/landscape? yes
/display/set/hardcopy/color/color
/display/set-window 1
/display/set/contours/clip-to-range? yes
/display/contour velocity-magnitude 0 1
/display/view/camera/zoom-camera 5
/display/hard-copy "dummy_%t_%n.jpg"
/solve/set/time-step 0.025
;number of physical time steps, number of iterations per time step
/solve/dual-time-iterate 1200 200
/exit yes
Cheers! Markus
Old   October 17, 2007, 11:30
Default Re: animation of transient simulation using batch
bashu
You can use 'solve' -> 'execute-command' and define two commands; first to plot every 'n' iteration and second to create a hard copy.
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 09:33
Batch issues to get results from a transient simulation aero ANSYS 0 November 10, 2009 07:32
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
