Error in Fluent with Euler + combustion?
Old   October 16, 2007, 08:14
Default Error in Fluent with Euler + combustion?
Aris Nikolopoulos
I have the following problem. I have converged a two face flow (Euler - Euler (granular)) cold flow (transient solution). When I tried to introduce a third combusting lagrangian phase a had severe problems with Energy equation. Trying to understand the problem, I tried to solve only the two Euler phases + the Energy equation (simple case, the two fluids enter with 600 kelvin and the walls have 1100 kelvin). I got a correct solution for a lot of seconds, but for a period of time (20 solution sec) mean temperature increased to 2000k!!! In this period all equation did converge.
The problem is severe!!! Do you believe that this is an error of Fluent? When i use the mixture model, i don't have any problems in temperature (but this model is insufficient for my applycation). Does anybody have the same problem?
I would appriciate your help!
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 05:10
Simulating combustion in fluent Silvia FLUENT 0 September 18, 2011 20:20
How to bring about combustion in FLUENT ??? black mamba FLUENT 0 April 30, 2010 20:38
Two phase flow - Euler in Fluent MartinP FLUENT 0 November 3, 2006 11:07
Fluent error in periodic PDF combustion cases?? George FLUENT 2 March 8, 2004 17:45
