v2f model implementation for airfoil in FLUENT
Old   October 15, 2007, 18:49
Default v2f model implementation for airfoil in FLUENT
Sunil
Hi, I am trying to simulate airfoil flow using v2f model. I came across the udf from a website to implement the model:
http://www.fh-pinkafeld.ac.at/fhplus/download.htm
I think I have the case file setting correct. I ran a simple channel flow and everything works fine. Whereas for the airfoil, the values go to Nan after about 50 iteration. I have tried reducing the urf and gone till 0.1, but the solution does blow up. The cd and cl values are very very high. To keep things simple its just a 2d steady state simulation.
If anybody has experience with the implementation of v2f in FLUENT, I'd appreciate if you could share your experience.
Thanks
Old   October 16, 2007, 02:48
Default Re: v2f model implementation for airfoil in FLUENT
selvaganesh
hi, instead of using UDF u can get the v2f model in Fluent turbulence panel itself. following is the procedure: define>model>vis>turbulence> after this type: <v2f model> enter
Old   January 16, 2014, 08:15
Kanarya is on a distinguished road
hi Sunil,
Can you help me about editing the source terms v2 and f in fluent?
did you edit them in the TKE or?
thanks in advance!
Originally Posted by Sunil
;146226
Thanks
Kanarya is offline   Reply With Quote
Old   December 3, 2015, 04:07
angela huang
Turbo_hrf is on a distinguished road
hello, I try to reach this website, but it did not work. why?
Turbo_hrf is offline   Reply With Quote
Old   December 7, 2016, 19:17
ali
alinik is on a distinguished road
Does anyone here has the UDF source files in the address mentioned in the very first post of this thread?
The files seems to have been removed from that address.
Thanks,
Ali
alinik is offline   Reply With Quote
Can FLUENT model flashing liquids? SWK FLUENT 9 June 22, 2017 02:17
heat transfer with s2s radiation model in fluent D. L. FLUENT 3 July 31, 2008 08:40
2D flapping foil- moving ref frame model in Fluent VJ FLUENT 0 October 20, 2007 02:15
V2f Model implementation vivek Kumar Main CFD Forum 2 April 8, 2006 12:27
How to use V2F in Fluent tomosada FLUENT 1 August 13, 2003 09:45
