October 11, 2007, 10:04 |
help high initial residuals
Hi
Hope any mathematician can help me. I am not using a cfd code but using a propriety code (not much inofrmation is avaiable about it) based on two fluid model with staggered mesh scheme. I have used steady state flowrates values as input BC with outlet BC constant at atmospheric pressure, I got results that were far from experimental values. next I tired putting experimental values (flow rates) as input BC keeping outletBC constant at atmpospheric pr. I also tried the reverse keeping experimental measured time series at outlet and keeping inlet BC (steady state values) at inlet BC. what I want to know is that in both cases there are few scattered high residual peaks in initial simulation till 400s (t=0 to 3600s) and then the residuals drops down to 10-8 and below. I was wondering whether the trends (of varaibles like P, V etc) obtained in first 500s are the artfacts of these initail high residuals peaks or physics behind the phenomena? looking forward to hear any suggestion. Aly |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 12:16 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
