October 9, 2007, 15:04 |
How 2 use both cores?
i have pentium D dual core processor ... how can i use both the cores while iterating in fluent???
October 10, 2007, 05:14 |
Re: How 2 use both cores?
To use both precessor start the Fluent launcher, you can define that in.
October 10, 2007, 05:21 |
wat is a fluent launcher??
October 10, 2007, 05:32 |
is thr a differnt parallel version of fluent to use both cores?
October 10, 2007, 05:59 |
It s not a different version, just set the Fluent launcher, you can find it in the laucher directory in C: fluent.
October 10, 2007, 06:11 |
i got the launcher .. and added the command C:\Fluentnewer\ntbin\ntx86\fluent.exe -r6.3.26 -t2 -pnet -antx86
but how can i make sure that both the cores r being used ? .. the CPU usaeg frm windows shows only one core being used more .... ie if one is 80% the other is only 30% |
October 10, 2007, 08:34 |
when you start Fluent you have to see something like that:
------------------------------------------------------------------------------ ID Comm. Hostname O.S. PID Mach ID HW ID Name ------------------------------------------------------------------------------ host net CAD5 Windows-x64 3728 0 1780 Fluent Host n3 mpich2 CAD5 Windows-x64 3852 0 3 Fluent Node In this case both the core will work. |
Specify number of cores that CFX should use. | Lance | CFX | 16 | July 20, 2016 10:04 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
6 Cores i7-980x | hellorishi | Hardware | 6 | August 3, 2010 12:20 |
UDF for vortex cores | Grace | Fluent UDF and Scheme Programming | 0 | March 18, 2010 06:19 |
Selecting cores independently in a dual quad core machine | jalarron | FLUENT | 1 | September 7, 2009 18:06 |
