October 8, 2007, 06:25 |
SolidWorks - FLUENT conversion
I haven't worked with FLUENT for a number of months and I am wonder how to convert a SolidWorkd (CAD) file into a FLUENT file with all faces pre-defined? |
October 8, 2007, 09:37 |
Re: SolidWorks - FLUENT conversion
U have to save the Solidworks file as a Parasolid file(with extension ".x_t"). Then you can import this file from Gambit. Then you can define all the boundary conditions and export it into FLUENT.
Hope this helps.... Madhukar |
October 8, 2007, 17:09 |
use the SW CAD connection tool which is free and comes with Gambit or FloWIzard.
October 11, 2007, 11:23 |
Dear Daniel Actually most of the CAD using conversion that well recognize by other CAD and also for Gambit
Such are : ACIS (make acis version 8) IGES etc But i prefer to ACIS, export your *.prt of your solid work dile to ACIS but choose version 8, because sometimes there is conflict, also u can open ACIS file in AUTOCAD or export AUTOCAD to ACIS then import the file from gambit, next u can examine your need in gambit for proper modeling by your condition and constraints Regards |
OpenFoam to Fluent data conversion Problem | vemps | OpenFOAM | 1 | August 8, 2011 02:30 |
Fluent jobs through pbs | ibnkureshi | FLUENT | 5 | June 9, 2011 13:43 |
converting a solidworks file into a fluent file | rhaul | FLUENT | 2 | June 23, 2006 16:04 |
Conversion from TETGEN to FLUENT | Jack | FLUENT | 1 | April 25, 2006 16:52 |
conversion of geo file from CFX-4 to fluent | Min-Hua Wang | FLUENT | 2 | January 26, 2000 17:01 |
