call for help
Old   October 6, 2007, 06:37
Default call for help
sihat
i have question iam using pipe fluid flow inside its diameter is 0.2m and the velocity is 3m/sec can you please send me user defined function using C for 3D inlet parabolic velocity thanks much in advance sihat
Old   October 9, 2007, 06:53
Default Re: call for help
sundar
dear sir, i am working in two phase flow through the pipe of dia 10mm. which model is best to simulate the experiment. which method of solver is best to calculate the pressure drop.what are the factors be considered. i am eagerly waiting for your reply.....
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 23:01
How to use q1 and ground file? zheh Phoenics 5 September 9, 2001 06:01
the use of WRTFIL Darcy Jiang CFX 6 May 9, 2001 03:16
Open source CFD code development, possible? Dr. Yazid Bindar Main CFD Forum 27 July 18, 2000 01:18
Who's ok for an Open Source CFD project ? Viet Main CFD Forum 16 July 26, 1999 16:57
