temperature limited
Old   October 1, 2007, 11:15
Default temperature limited
Y.harnane
hello; I'm modeling turbulent mixed convection in periodic horizontal ribbed channel with heat flux at the horizontal face. when I used K-eps model and it's variants the simulation converged; but when I changed the model to K-omega and RSM with the same conditions after a long iterations I obtained a temperature limited.. I don't undrestand why? can any one help me please!! thank you
Old   October 2, 2007, 10:27
Default Re: temperature limited
PratiK Mehta
try to change the underrelaxation factors for pressure and temperature. Use PISO for pressure velocity coupling and PRESTO for pressure discritization . If this doesnt help then you really should run the system unsteady.i hope thid helps
let me know ,hows the solution
TEMPERATURE LIMITED problem emanuele FLUENT 9 June 15, 2018 11:45
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
temperature limited - absolute pressure limited Asashi FLUENT 3 July 18, 2014 10:51
temperature limited to 1.0e-00 in 10 cells fabolous FLUENT 1 July 14, 2010 14:48
the sign "temperature limited to sth..." Kwang FLUENT 0 October 21, 2007 07:18
