how to implement some equations
Old   October 1, 2007, 09:56
Default how to implement some equations
Renato Pacheco
i need to implement some equations in fluent. this equations i dont know if are the same fluent uses, but i need to use a premixed combustion and i must use the equations that i have in a paper. how to do it?
Old   October 2, 2007, 06:21
Default Re: how to implement some equations
Jim
Most likely you have to incorporate them as a User-Defined Function (UDF) I think. Do you have access to Fluent users service? I think that there is a similar problem to yours in the tutorial pages and the udfs help.
Old   October 2, 2007, 06:25
Renato Pacheco
thanks for your answer. I dont have access to this documents. Do you have it to send to me?
Old   October 2, 2007, 07:00
Jim
Try to seek access from your institution (if you're at university) or the IT technician (if you work). Otherwise in the Fluent window go Help and choose index, user's guide, there should be plenty of information on premised combustion with examples and theory... maybe you'll find that you don't need to write the equations after all!
I'll try to find a sample udf so you can get an idea. Unfortunately, combustion is not my interest so I know little about it, but just try the above and let me know if it goes.
Old   October 2, 2007, 07:18
Renato Pacheco
ok. there no example about premixed, but i am trying to change the example about other equations implementation.
Old   October 2, 2007, 11:54
Renato Pacheco
actually do you have an udf with other kind of equations implemented? so i can take a look on it...
Guide: Writing Equations in LaTeX on the CFD Online Forums pete Site Help, Feedback & Discussions 27 May 19, 2022 04:19
Favre averaged Navier-Stokes equations help siw Main CFD Forum 3 June 24, 2016 12:26
CFD governing equations m.gos Main CFD Forum 0 April 30, 2011 15:21
solving only turbulence equations afroz_javed OpenFOAM 1 January 20, 2011 06:25
? fluctuating equations for homogenous shear turb. ff_fan Main CFD Forum 1 September 20, 2002 08:39
