Data import in Fluent?!
Old   September 26, 2007, 13:13
Default Data import in Fluent?!
Bart Horsten
When I run a calculation in Fluent, I want to export data (velocity and pressure data from the resulting data file) to a file. Because this data is to be compared to experimental data, the x,y,z coordinates of the data probe points do not allow for the creation of a rake (they are in curved lines for instance). How can I import a set of coordinates into Fluent without having to specify all these points by hand?
Old   February 22, 2010, 08:21
Feitan is on a distinguished road
I have the same problem, is there anyone who can help us?
Thank you very much.
Feitan is offline   Reply With Quote
Old   February 22, 2010, 08:36
Bernhard
Bernhard is on a distinguished road
With journalfiles you can easily specify all these points.
But what type of experiment gives a goog reason to measure along some curve?
Bernhard is offline   Reply With Quote
Old   February 22, 2010, 14:05
Well the probes are placed on a generic 3D surface, not exactly on a curve. I have a file with the probe coordinates and I want to know the value of the pressure at these points. According to you I need "only" to create a journal file in which I "tell" fluent where to find the file with the point coordinates. Do I have to copy and paste the coordinates in the journal? Thanks * * *
Fluent to Radtherm (export of data) akd FLUENT 0 December 3, 2010 02:07
import fluent cas.gz files bramv101 STAR-CCM+ 0 September 23, 2009 09:28
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 02:08
Importing Gambit data into Fluent Tyred ANSYS Meshing & Geometry 1 April 18, 2009 14:53
Import data from another .cas file of fluent Umesh FLUENT 1 August 17, 2003 05:51
