November 6, 2017, 10:12 |
#21 |
Sorin Munteanu
Rep Power: 14 |
Hi Taes,
I will advise you to use actfluentserver instead. Please read the blog below for more detailed information. http://www.ansys-blog.com/how-to-mak...pps-for-ansys/ Sorin |
May 25, 2020, 19:15 |
#22 | |
Eva
Hi, I'm using now Im using AAS- to couple Matlab (2018b) and Fluent (2019R2) and use it as a Server. I have followed the steps in the official Ansys Youtube tutorial for the connection, and have read the users guide: "Fluent as a Server". Most of functions seem to work such as: tui.doMenuCommandToString(), fluent. getNrInputParameters(); fluent.getInputParameterNameByIndex(in long lInputParameterIndex); Nevertheless, the most important functions that I need do not work: (WRITE AND READ PARAMETERS of Fluent) fluent.getOutputParameterValueByName(string('q_rad _thorax')) fluent.setInputParameterValueByName(string('T_head '), 200) I write an example of what Im coding: %%%%%%%%%%%%%%% CODE %%%%%%%%%%%%%%%%%% %% Basic Connection %%%% RUN THIS SECTION - Once per matlab session orb=initialize_orb(); load_ansys_aas(); fluent=actfluentserver(orb,'aaS_FluentId.txt'); tui=fluent.getSchemeControllerInstance(); tui.doMenuCommandToString('report summary') %tui.doMenuCommandToString('define operating-conditions gravity yes 9.8 0.0 0.0'); fluent.getOutputParameterValueByName(string('q_rad _thorax')) fluent.setInputParameterValueByName(string('T_head '), 200) %%%% MATLAB OUTPUT ERRORS: >> fluent.setInputParameterValueByName(string('T_head '),200) Java exception occurred: AAS_CORBA.EFluentGenericError: IDL:AAS_CORBA/EFluentGenericError:1.0 at AAS_CORBA.EFluentGenericErrorHelper.read(EFluentGe nericErrorHelper.java:80) at AAS_CORBA._ICoFluentUnitStub.setInputParameterValu eByName(_ICoFluentUnitStub.java:456) >> fluent.getOutputParameterValueByName(string('q_rad _thorax')) Java exception occurred: AAS_CORBA.EFluentGenericError: IDL:AAS_CORBA/EFluentGenericError:1.0 at AAS_CORBA.EFluentGenericErrorHelper.read(EFluentGe nericErrorHelper.java:80) at AAS_CORBA._ICoFluentUnitStub.getOutputParameterVal ueByName(_ICoFluentUnitStub.java:579) PD: I have already written in my Fluent case these parameters previously, so they exist. I have also tried writing fluent.getOutputParameterValueByName('q_rad_thorax ') and neither works. The error that I get from at FLUENT command window: unbound-variable, set-parameter-data Thank you very much, Any help would be really welcome. |
July 30, 2020, 09:14 |
Fluent aas Matlab for Linux
#23 | |
Hi! I have exactly the same problem and was wondering wether you found a way to work around this? Or is it only possible with that Matlab extension in the blog? Kind regards, Carlijn |
June 9, 2021, 14:02 |
#24 |
Rep Power: 6 |
June 18, 2021, 10:07 |
#25 | |
% launch Fluent pathToFluent = ' "/share/apps/ansys192/v192/fluent/bin/fluent"'; args = ' -v2ddp -g -aas -i JournalModel.jou &'; [s, out] = system([pathToFluent args]); % wait for fluent aas file to be generated and the journal file to be read pause(90) % do the actual coupling orb=initialize_orb(); load_ansys_aas; fluent=actfluentserver(orb,'aaS_FluentId.txt'); tui=fluent.getSchemeControllerInstance(); tuiCommand=['/file/interpolate/write-data "',SigmaPath,'/InterpolationOutputFile.ip" n y-velocity x-velocity pressure () n']; tui.doMenuCommand(tuiCommand); Hope this helps you! ps. Sorry for my late response, the message ended up in my junk mail box, so I hadn't seen your question |
Ansys 12.1 - Create Rotor/Stator Interface for Fluent | opm | ANSYS Meshing & Geometry | 21 | May 23, 2016 09:29 |
Interface boundary, Fluent | natantyt | FLUENT | 2 | October 18, 2011 08:46 |
Fluent & matlab | Fabio | FLUENT | 5 | August 24, 2009 14:16 |
interface reconstruction algorithm in Fluent VOF > | daniel | Main CFD Forum | 0 | May 4, 2006 04:25 |
Call Fluent from Visual Basic 6 interface | AbuKhawlah | FLUENT | 0 | June 5, 2005 15:53 |
