September 25, 2007, 06:28 |
plz help its urgent
hi
thanx for ur guidance ok if the backflow volume fraction for the phase which is not being asked is taken as 1-(the volume fraction specified for other phase), then can u plz tell what boundary condition shud i take if i want the following situation to model: my system consists of a rotating cylinder(i.e. rotor of the centrifugal contactor) in which i m employiong the use of VOF model to simulate fluid flow in it. the cylinder has an inlet at the bottom thru which water enters and it goes out thru the top annular ring. this annular ring at the top is defined as pressure outlet b.c. , also there is a small opening at the centre of the top which lets the water rotating in cylinder exposed to atmosphere. so there are 2 fluids air and water. now at the top where i hav specified pressure outlet b.c. i need only water to leave out and no backflow of it and also no air shud come in or going out thru that opening then how shud i employ that . plz guide thanks garima |
Jet flow problem.. PLZ help URGENT!! | Vinayak | CFX | 1 | April 3, 2008 19:02 |
Plz help on MHD. Urgent! | Rucy | FLUENT | 2 | May 27, 2007 21:46 |
DEFINE_SOURCE : Urgent PLZ | PK | FLUENT | 3 | December 14, 2006 16:06 |
Urgent: Plz help in 3D extension of Fluent code... | Farooq | FLUENT | 0 | November 27, 2003 23:28 |
Urgent..plz help | Puck | FLUENT | 6 | July 29, 2002 05:15 |
