September 23, 2007, 00:39 |
how to do after Floating point error is told
hi,all i is using VOF technique to model fluid free surface under over 101500 pascal.Under-relaxation factors are 0.3 or 0.1, first order upwind,using k-epsilon model, my computer tell me:
Updating solution at time level N... done. physical-dt 1.0000e-005 iter continuity x-velocity y-velocity z-velocity k epsilon time/iter reversed flow in 2287 faces on pressure-outlet 8. Error: Floating point error: invalid number Error Object: () i want to know that i should deal with flouting point error? |
September 24, 2007, 10:16 |
Re: how to do after Floating point error is told
MPI Error - simpleFoam - Floating Point Exception | scott | OpenFOAM Running, Solving & CFD | 3 | April 13, 2012 17:34 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 05:59 |
reactingFoam floating point exception | pajofego | OpenFOAM | 0 | November 6, 2010 18:29 |
floating point exception? | syd | STAR-CCM+ | 3 | April 20, 2010 19:55 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 03:27 |
