partcle tracking (aborted trapped incomplete)
Old   September 21, 2007, 09:54
Default partcle tracking (aborted trapped incomplete)
Fabrizio
I'm looking at a fluent simulation. It involves particle tracking and it is a steady computation both in continuum and discrete phase.
When discrete trajectories are computed I see this output:
number tracked = 31, escaped = 11, aborted = 2, trapped = 7, evaporated = 0, incomplete = 12
I have two problems.
1) I don't understand what means "aborted", "trapped" and "incomplete" tracked particle. I mean I don't see the difference among this definitions. (The particles are inert material).
2) Moreover if I did a steady computation I would expect that every injected particle leave the domain, otherwise the number of particles inside the domain should increase and so it should not be possible to find a steady solution. Am I wrong?
Thank you for any clarification.
Old   September 21, 2007, 10:14
Default Re: partcle tracking (aborted trapped incomplete)
bli
For the first question, I suggest you refer to the User's Guide, Discrete Phase Models, Postprocessing for the Discrete Phase, Reporting of Trajectory Fates:
"Aborted'' trajectories are those that fail to complete due to roundoff reasons. You may want to retry the calculation with a modified length scale and/or different initial conditions.
"Trapped'' trajectories are those that terminate at a flow boundary where the "trap'' condition has been set.
"Incomplete'' trajectories are those that were terminated when the maximum allowed number of time steps--as defined by the Max. Number Of Steps input in the Discrete Phase Model panel--was exceeded.
For the second question, the particles tracked in the previous discrete phase calculation will not 'stay' in the computational domain as you imagined. They don't accumulate even named by 'incomplete' etc.
Old   September 21, 2007, 10:26
Fabrizio
Thank you very much for your reply. It helps me a lot ( I didn't find that on the user guide!)
Regarding the second question as far as I understood only trapped particles would stay inside the domain. Am I right?
Old   September 21, 2007, 10:42
bli
You are welcome.
But still, in the steady state calculation, none of the particles in previous discrete phase calculation will appear in the next calculation.
Old   September 21, 2007, 13:15
Fabrizio
Ok. Thanks again.
compilation problem with "fvPatch::lookupPatchField" Ya_Squall2010 OpenFOAM Programming & Development 9 November 15, 2021 23:01
Particle tracking trapped or incomplete Abigail FLUENT 5 July 30, 2015 11:37
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 21:23
too many particles trapped on wall with tracking Wouter FLUENT 0 August 11, 2008 12:15
