#21 |
ribes
Rep Power: 0 ![]() |
An other simple way to get the residuals is to type
/plot/residuals-set/plot-to-file “res_file_name.txt” You will get all the residuals stored in memory (same as used for plots in Fluent's GUI) |
#22 |
George XU
Rep Power: 16 ![]() |
To write out the residuals from fluent, the following two steps in TUI are recommended to follow:
1. /plot/residuals-set/plot-to-file “res_file_name.txt” 2. /plot/residuals Then the residuals selected will be written out to the specified file. Details about the iteration interval might be set with commands under /plot/residuals-set. |
#23 |
alberto
Rep Power: 10 ![]() |
Does any one how to write the residuals when the simulation is running? I am running in HPC and I want to plot this residuals on the fly.
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
Velocity blows up suddenly after 30,000+ iterations | lordvon | OpenFOAM Running, Solving & CFD | 15 | October 19, 2015 13:52 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
MRFSimpleFoam amp cyclic patches | david | OpenFOAM Running, Solving & CFD | 36 | October 21, 2008 21:55 |
