Time Series Export
Old   September 19, 2007, 06:55
Default Time Series Export
ANASTASIOS GEORGOULAS
Dear All,
I an running an unsteady simulation and i have set the auto save tool to save .cas and .dat files every 10 time steps.
Does any body know how can i produce time series of lets say velocities after the end of the simulation.
E.g. how can i produce the graph of velocity(in a certain point) versus time.
Thanks very much in advance,
Anastasios
Old   September 19, 2007, 11:09
Default Re: Time Series Export
Gernot
You can set a monitor under solve / monitors / surface
there you can write out all parameters on faces or points every timestep / or iteration as graph and/or file.
hope that helps
Gernot
Old   September 19, 2007, 11:39
Anastasios Georgoulas
Thanks very much for your response Gernot, i will try it immediatelly thanks!
Anastasios
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Time series of max plume height HMR CFX 5 August 3, 2011 08:46
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
Export AreaAve data at each time step in CFX Post Kumar CFX 2 August 22, 2007 13:32
