incorrect temperature in pressure based solution
Old   September 19, 2007, 00:21
Default incorrect temperature in pressure based solution
Kian
I am comparing solutions of pressure based and density based solutions for the transient case below: Inviscid flow of air (perfect gas) in a 1-meter long tube (2-D). There is no flow initially, but using tables, the mass flux and temperature uniformly increase at the inlet B.C.
Two simulations, density based and pressure based are performed using the same time step (2.0E-05) and implicit formulation. The mesh size is 500x20. Obviously there is no need to have 20 grids in the direction normal to the flow, as we are basically modelling a one-dimensional flow.
After some time (2.5 milliseconds), the profiles of pressure, density, velocity, and temperature are compared between the density based and pressure based solutions.
All match quite well, except for temperature, which has a different and incorrect trend at the pressure based solution.
Any comments? The plots are available at:
http://www.time-step.org/cfd/index.html
Thank you,
Kian
Old   July 6, 2009, 06:59
Giuki Cael
Giuki is on a distinguished road
Dear Dian,
I have the same problem, with a different case but still. I'm having a pressure inlet, using the pressure-based solver, and would like to have a temperature of 800K. But my guess is due to the pressure inlet and the temperature dependence of Cp. I get temperatures of more than 1200K at my inlet.
Have you found a solution for your problem?
Regards,
Giuki
Giuki is offline   Reply With Quote
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
Pressure Boundary Solution AsafPa OpenFOAM 0 October 28, 2010 10:22
Pressure temperature variation Dev CFX 0 June 22, 2007 00:01
Pressure based and Density based Solver Xobile Siemens 1 November 30, 2004 22:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
