Unable to Initialising to M=1.71
Old   September 13, 2007, 04:25
Default Unable to Initialising to M=1.71
ravi
I am trying to solve a supersonic flow of M=1.71 (472 m/s)over a cavity in side a test-section. I gave the inlet as pressure inlet and outlet as pressure outlet. I calculated the static pressure and temperature exactly. In MATERAILS i selected ideal-gas and sutherland formula.
But when i m tryin to initialise at the inlet, the velocity is 392 m/s only i.e M=1.4. that means i m not able to get M=1.71 at the inlet, whicih i specified in boundary conditions. where m i goin wrong. can somebdy help me pls...
thanks ravi
Old   September 14, 2007, 03:04
Default Re: Unable to Initialising to M=1.71
raj
hi!
initialisation takes average value all over the grid(or by some other means), it need not necessarily take the 1.71 at inlet, as the solution converges, the b.c's will get satisfied. its the iteration procedure, which takes rough values at the start and refine them through the iterations.
regards, raj.
Old   September 14, 2007, 03:37
rav_aero
no with iterations the M value didnt change. I have checked, even after 26,000 itterations the value is still 1.4 only.
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 12:03
Sun Grid Engine grtabor OpenFOAM Running, Solving & CFD 28 August 22, 2012 10:27
openfoam 1.6 on debian etch romant OpenFOAM Installation 9 May 6, 2010 03:26
fluent nithin20k Main CFD Forum 1 January 12, 2010 20:37
[Commercial meshers] ST_Malloc: out of memory.malloc_storage: unable to malloc Velocity SA, cfdproject OpenFOAM Meshing & Mesh Conversion 0 April 14, 2009 16:45
