Using compiled UDF:s in different Fluent versions
Old   September 11, 2007, 10:43
Default Using compiled UDF:s in different Fluent versions
S H
I tried to open a case file with already compiled UDF:s in a newer version of Fluent than they were compiled in, in the first place. I then get error message saying that fl6216s.exe is missing. After some investigation I interpretate this as the case-file is calling for the older version (fl6216s.exe = Fluent 6.2.16), and when it is not found the program collapses.
Summary: is it really so that UDF:s compiled in older versions of Fluent cannot be used in newer ones?
Old   September 12, 2007, 04:40
Default Re: Using compiled UDF:s in different Fluent versi
Frederik
Yes, that could be the case -as far as I understand it the compilation is platform specific so if you change system/software it could require a re-compilation.
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Educational versions of Fluent danny261083 FLUENT 3 June 27, 2013 05:58
Compiled UDFs - questions Antonis FLUENT 6 December 26, 2012 07:12
Linking pre-compiled UDFs to Fluent gracerlima Fluent UDF and Scheme Programming 2 April 3, 2010 15:16
compiled UDFs Jianli FLUENT 5 December 14, 2004 04:20
