how to calculate viscous and inertia resistance
Old   September 10, 2007, 07:19
Default how to calculate viscous and inertia resistance
mourya
Dear friends , pl help me in calculating viscous and inertia restance for know pressure drop and velocity.
velocity-m/sec pressure drop-pas 1.02 9.7 1.27 13.7 1.52 17.9 1.78 23.6 2.03 28.4 2.29 33.6 2.54 39.8 2.79 46
thanks with Regards
Old   September 11, 2007, 06:49
Default Re: how to calculate viscous and inertia resistanc
Grey
Using Darcy's pressure drop equation i guess
Old   September 11, 2007, 09:33
Babar
Look at Section 6.19 of the Fluent tutorial. You can use equations 6.19-16 and 6.19-17 to calculate the viscous and inertial resistances.
Old   September 11, 2007, 12:55
chandra manik
first you have to plot the value you get( pressure and flow) after that fitting those gprahic to find aproriate contant value
delta p = Av^2 +BV fitting this graphic using exel, you get the value of A and B you can get the value of C2(inertial resistance) and alfa (viscous resistance) by making relation
that : A= (C2*rho*delta n)/2
and B = (dynamic viscosity/alfa)* delta n
where n is thickness of your layer, filter or whatever as porous media
but be carefull, u fave to collect data in all porous open, half open and 25% open, so u can get data as when valve fully open, half and 25%
i hope this will help
correct me if i wrong
