fluid flow problem in 3D tube
Old   September 9, 2007, 19:55
Default fluid flow problem in 3D tube
gurunarayana ravi
Can some one tell me how to
form a 3D grid in a 3D tube apply fluid boundary conditions ( inlet velocity,outlet velocity)
I need to know wat r the boundary conditions and what faces I need to select.
It will also be nice if someone can tell how to solve the same problem with heat transfer assuming a constant wall heat flux. I need to know wat faces to select in gambit and the boundary conditions
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
Problem with using icoFoam for flow in a straight tube edificelp OpenFOAM 4 February 11, 2011 04:27
Fluid flow caused by initial pressure difference perry.fox FLUENT 1 December 24, 2010 09:42
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
