How to send nonconformal case to parallel
Old   September 7, 2007, 14:38
Default How to send nonconformal case to parallel
Lily
I'm using nonconformal grid in a Fluent case. It worked when I was using one single computer, but failed when I tried to put them into parallel calculation. Can anyone tell me how to solve this problem?
Thanks so much.
Old   September 7, 2007, 17:50
Default Re: How to send nonconformal case to parallel
JAI SHANKAR V P[
I AM JAI SHANKAR V P . I AM CURRENTLY WORKING AS SENIOR LECTURER WITH SNMIMT IN INDIA .I AM CURRENTLY COMPLEATING MY MASTERS IN PRODUCTION ENGINEERING WITH COCHIN UNIVERSITY OF SCIEANCE AND TECHNOLOGY , KOCHI, KERALA , INDIA
I AM VERY INTRESTED IN THE SUBJECT OF CFD .
CAN I GET ANY HELP FORM YOU IN THE SAME . MY EMAIL ID IS shankarvp@yahoo.co.in
HOPE U WILL HELP ME INTHIS ISSUE
WITH REGARDS
JVP
Old   September 7, 2007, 19:03
Andrew Berner
If memory serves, the problem has to do with the segmentation of the mesh for parallel distribution across a non-conformal boundary. Fluent 6.3 does this properly, I think, but 6.2 had issues. If you're trying this under fluent 6.3, I think a little more information about your specific case would help in determining the difficulty. This can be made to work under Fluent 6.2, but I think you need to carefully segment the mesh such that either the entire non-conformal interface is within one chunk of the mesh, or that the mesh segments perfectly match the non-conformal interface. I may be off on this-- somebody please correct me if I am. Hope this helps...
Andy
Old   September 8, 2007, 09:33
Joe
Continue to post this crap and your IP will be banned, permanently.
Old   September 9, 2007, 09:13
Karim
Hey, Jai Why are you so shameless? Can you not understand that nobody is going to teach you CFD. There is a lot of resources in the internet for learning. Just search and read those materials or take a course on CFD in your institute. As a Lecturer, don't humiliate yourself.
Old   September 10, 2007, 15:53
Lily
i work under fluent 6.2
Post processing a parallel case Gearb0x OpenFOAM Post-Processing 11 March 8, 2022 13:16
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 17:31
Parallel Moving Mesh Bug for Multi-patch Case albcem OpenFOAM 0 May 21, 2009 01:23
how to parallel run in moving mesh case ELYOR Siemens 5 June 16, 2008 04:23
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 07:33
