Parallel plates
Old   September 5, 2007, 13:52
Default Parallel plates
pelli
Dear all
I'm running a water flow simulation in a squared parallel plates system with hydraulic aperture 0.85 mm and length 1 meter,the discharge i obtained is slightly higher than the cubic law prediction (2%), while i expected it to be slightly lower due to numerical diffusion. Can you give me some advice, thanks a lot.
Old   September 5, 2007, 21:16
Default Re: Parallel plates
Joe
Numerical quality control: Mesh sensitivity tests, ...
Radial flow between parallel plates gfcoppola OpenFOAM Running, Solving & CFD 1 October 22, 2010 06:42
2d cfd parallel plates Animeile CFX 1 April 21, 2010 17:24
Injection between parallel plates, homogenous mode Terje CFX 7 September 7, 2008 20:51
Flow between 2 parallel flat plates pelli FLUENT 2 July 14, 2007 10:59
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
