Mixing occuring faster than the experiment problem
Old   September 4, 2007, 09:40
Default Mixing occuring faster than the experiment problem
Lila
Hello, I'm doing a simulation investigating water mixing in tanks. The model involves two phases (fresh & saline water) and use of turbulent jets. I've used the RNG K-E model and VOS multi-phase model. It's an unsteady simulation and I've used a time step of 0.1 secs. Although FLUENT predicts velocity fields very accurately, mixing occurs much faster than the experiment. I've tried changing under relaxation factors with no success. Any ideas why this is happening? Any suggestions?
Please, help!!!
Old   September 5, 2007, 21:05
Default Re: Mixing occuring faster than the experiment pro
Joe
Turbulence model is the likely culprit.
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 15:31
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
Mixing occuring faster than the experiment problem Lila Main CFD Forum 1 September 5, 2007 11:48
problem with MFR model for multiphase mixing tanks Srinivas Main CFD Forum 1 November 7, 2005 15:16
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 10:11
